Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Looking for a 16x1.5mm die
Old Jul 9, 2003 | 05:05 PM
Andrew Mason's Avatar
Default Looking for a 16x1.5mm die
Hey there,
Haven't posted in a while, but then I saw this new forum, looks great...
Anyhow, like the title says, I need a 16x1.5mm die to cut threads on my B&M ripper when I cut it down. I have heard people have just welded a bolt with that thread onto the end of the stick after cutting it, but I'd like to try this first. I can't find an affordable set that has this size, the only ones that do are way too expensive for now.
Does anyone know where I could pick up this die all by itself?
Thanks,
Andrew
Old Jul 11, 2003 | 09:38 AM
jmd's Avatar
jmd
Default Re: Looking for a 16x1.5mm die
http://www.jtsmach.com/
That place has some seriously oddball tap & die sizes. I got a 13/16-16 tap from them. Haven't had an opportunity to use it; might never use it, but they got it to me once it was in stock. Poland made.
g/l w/ your project.
-Matthew
Old Jul 14, 2003 | 12:33 PM
Thanks alot Matthew!!!
Old Jul 14, 2003 | 02:50 PM
DERTY's Avatar
The Bull
You can also goto McMaster.com. They have more crazy stuff on their site than anywhere else. The part number for the die is 8294A64.
Old Jul 14, 2003 | 05:47 PM
trackbird's Avatar
I don't think you 'll actually manage to cut threads on that shifter handle with a tap. I suspect you'll need to have a machine shop use a lathe and cut threads on it. That handle is some seriously stout stuff. Nothing is impossible, but you better buy a couple dies....just my thoughts...good luck!
