Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Any experience w/ Campbell Hausfeld air tools?
Old Jul 11, 2003 | 11:38 AM
Bad1le's Avatar
Default Any experience w/ Campbell Hausfeld air tools?
Anybody have campbell hausfeld air tools, how do they hold up?
AJ
Old Jul 11, 2003 | 11:57 AM
Camaroholic's Avatar
Default Re: Any experience w/ Campbell Hausfeld air tools?
I have a bunch of them. Infrequent user, but the air tools are ~7 years old. Impact, 3/8 ratchet, die grinder, drill... The only one that's had problems was the ratchet. It stopped turning when under pressure (it would free wheel, but whenever you put it on a bolt, it wouldn't turn it). I took it apart, put it back together, and it works fine now.
I don't know if I'd use them every day in a shop, but for a weekender, they work fine. I've also got a C-H air compressor, ~7 yrs old, noisy as hell, but still works fine.
-Andrew
Old Jul 11, 2003 | 12:33 PM
mitchntx's Avatar
I have C/H 1/4" ratchet and 3/8" ratchet, Both have held up well for several years under limited use.
I have a 1/2" C/H impact gun and a 1/2" Craftsman impact gun. Both are rated at the same PSI/cfm, yet the Craftsman will out torque a bolt by 50ft/lbs.
Old Jul 11, 2003 | 12:36 PM
eitek1's Avatar
I have to say the same thing. I have had mine for years and have never had a problem they have all worked fine.
Old Jul 11, 2003 | 12:53 PM
Bad1le's Avatar
Thanx for the replies guys!
AJ
Old Jul 11, 2003 | 01:29 PM
2KVetteMan's Avatar
AJ
AJ you need to e-mail me!!
Old Jul 11, 2003 | 01:54 PM
Bad1le's Avatar
AJ
Sent you an email
AJ
Old Jul 11, 2003 | 06:02 PM
Visceral's Avatar
I think they are fine, but I used to have an impact wrench of theirs that was rated at 500 lb/ft. I think it really maxed out at 250 or 300 at 110 psi.
chris
