Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Help me find this valve spring tool?
Old Jul 29, 2003 | 08:45 AM
Mustang Hat'r 2's Avatar
Default Help me find this valve spring tool?
I seen a post on this a while back and now cant find it. Its just a flat peice of steel that you use a rocker arm bolt on and it will compress the spring. Anyone know what I am talking about? I dont have any $$ to buy one and got some 3/8 steel and can make one of these up, I need to change my valves ASAP.
Thanks
Old Jul 29, 2003 | 01:10 PM
Ramair346's Avatar
Default Re: Help me find this valve spring tool?
napa has em
Old Jul 29, 2003 | 01:58 PM
This thing was home made. Dont think napa has them unless they stole his idea.
Old Jul 29, 2003 | 05:38 PM
Nevermind I found it.
Old Jul 29, 2003 | 10:04 PM
pimpmaro's Avatar
Be careful, my experience with that is that the thing is crap. I'd go ahead and work with something like the 40 dollar snap on compressor. There are a lot of options out there that are quality tools. The modified napa tool just was bad luck for our cam install. We got a bolt snapped into the heads.
Old Jul 30, 2003 | 07:01 AM
Which one are you talking about? They have like 20 different valve spring compressors on there site.
Old Aug 1, 2003 | 08:39 PM
Tally TransAm's Avatar
the one i made, which im sure you found my pic with the dimensions and stuff, works great
just use a few washers as spacers and make sure you get 4-5 good turns into the rocker arm bolt hole before it grabs the tool and itll work fine. done quite a few spring changes with it with no problem at all
ryan
