Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
valve spring compressor
Old Aug 7, 2003 | 07:27 PM
Air21's Avatar
Default valve spring compressor
i'm looking for a valve spring compressor simular to the More Perfroamce valve spring tool for ls1/ls6's. Can this be used on standard SBC heads?? Or does anyone know where i can get one thats made for sbc?
Old Aug 10, 2003 | 09:29 PM
wrencher's Avatar
wrencher
Default Re: valve spring compressor
They have one that is like a flat piece of 1/4 steel.
It is curved slightly & mounts one the rocker arm stud.
Not good if clearance is an issue.
Alot of tool companies make 'em.
Old Aug 24, 2003 | 05:06 PM
Air21's Avatar
i have that one, but you cant use it to change the springs while the heads are on the car, bitch to use on heavy springs too
Old Aug 25, 2003 | 07:19 AM
Larry's Avatar
Glenn,
I have you down for one of mine.
https://ls1tech.com/threads/showflat...=7&fpart=1
Old Aug 26, 2003 | 11:23 AM
GREGGO's Avatar
Moderator
Tbyrne has a kit with the spark plug air compressor fittings.
