User Support & Resources Account Problems | Questions | Suggestions
mobile skin
Old Feb 25, 2009 | 06:05 PM
torquejunky's Avatar
Default mobile skin
I swapped over to mobile skin on my phone now I can't get rid of it....
Old Feb 25, 2009 | 06:32 PM
tried clearing cache/cookies still there
Old Feb 25, 2009 | 08:14 PM
JeremyT's Avatar
Unless you went into your userCP section, and under the Edit Options, changed the Forum Skin to mobile, it should have been reverted back to default if you really did empty your cookies. If you change the skin in your userCP section, the changes are saved to your account. If you simply change the skin via the drop-down menu located on the bottom left of each page, it is done via cookies. If the latter, clearing your cookies should have defaulted back to the ls1tech style.
The creator of the mobile template might want to consider adding the following link in the footer of the mobile template:
https://ls1tech.com/forums?styleid=19
Anyone stuck in the mobile template could simply click on the above link and get back to the default ls1tech style. Seems like many users appear to get stuck in the mobile section because this is not done.
Old Feb 26, 2009 | 12:58 PM
Thanks, that fixed it. Not sure why they have not made that link available.
Just an FYI, I still had to go back to the userCP and change the option back to a "normal" skin. When I logged back in it reverted back to the mobile skin.
Old Feb 26, 2009 | 04:06 PM
JeremyT's Avatar
If you initally changed to Mobile view while in the UserCP section, then the change becomes permanent to your account. In that case the only way to permanently change it is by revisiting the UserCP section. The drop-down menu on each page will override your UserCP setting, but it won't be permanent as the drop-down menu on each page is simply cookie based.
Basically, UserCP = permanent on your account while drop-down menu on the left side of each page is temporary via cookies.
