User Support & Resources Account Problems | Questions | Suggestions
Search Function Problem
Old Apr 11, 2009 | 10:55 AM
Yeajimi's Avatar
Default Search Function Problem
I have been notified how to use the search function. The only problem I had w/ this suggestion is the misunderstanding of how the search function works.
"Use quotation marks - If you feel that the words you are searching for may commonly be together, place quotation marks around them (i.e "fuel injector"
Using quotes in this forums search bar does NOT mean the words in quotes will come back as a phrase. It merely changes the search from an OR statement using the words you have supplied to an AND statement. IE if you type in "LS1 Manifold" you will get results that include both words, but they are not neccessarily in the same post. The best option is to add a search option that allows you to search for any of the terms, all of the terms and then allows for use of " " for searching of phrases.
Old Apr 24, 2009 | 12:07 AM
IB Adrian's Avatar
IB
It does now - thanks, we have fixed it
