User Support & Resources Account Problems | Questions | Suggestions
cant switch to mobile version
Old Jun 21, 2009 | 01:57 PM
taws6m6's Avatar
Default cant switch to mobile version
\I can't switch to the mobile version on my phone. I had it, I switched to the regular and now it will not go back. is something wrong?
Old Jun 21, 2009 | 02:57 PM
JeremyT's Avatar
Do you mean that when you try to select LS1Tech Mobile from the drop-down menu on the bottom left of the screen that nothing happens?
If so, make sure that javascript is enabled. That menu option requires javascript be enabled, which can often be disabled on mobile phones.
You could always bookmark the following link on your mobile phone:
https://ls1tech.com/forums/index.php?styleid=23
The above link will take you to the mobile version, and is cookie based. This means that whenever you browse with your mobile phone, if you use the link above, you'll see the mobile version. However, when you then browse on your desktop machine, you'll see whatever version you had previously been using.
Use this link if you need to go back to the "default" on your mobile phone:
https://ls1tech.com/forums/index.php?styleid=19
Old Jun 21, 2009 | 03:52 PM
taws6m6's Avatar
great! thanks man. idk what's wrong I switched cause I wanted to view something and went back and wouldn't work. works now
