ls1tech mobile setting?
Otherwise, there are two threads on the front page of this forum about LS1Tech's mobile support:
https://ls1tech.com/forums/user-supp...pp-iphone.html
https://ls1tech.com/forums/user-supp...e-ls1-app.html
You could always bookmark the following link on your mobile phone:
https://ls1tech.com/forums/index.php?styleid=23
The above link will take you to the mobile version, and is cookie based. This means that whenever you browse with your mobile phone, if you use the link above, you'll see the mobile version. However, when you then browse on your desktop machine, you'll see whatever version you had previously been using.
Use this link if you need to go back to the "default" on your mobile phone:
https://ls1tech.com/forums/index.php?styleid=19
But if you want to make the drop-down menu work, and other features on this forum work, you need to enable javascript in your mobile phone's browser.
