User Support & Resources Account Problems | Questions | Suggestions
Sig pic problem
Old Nov 15, 2009 | 07:56 AM
n2ocamaro's Avatar
Default Sig pic problem
I went to change my sig pic for the BMR/Nitrous Outlet promo and it would not add the pic to my sig. I tried to put my old sig pic back in and it will not show up. Is this a complication from the cyber attacks?
Old Nov 15, 2009 | 05:03 PM
studderin's Avatar
same here?
Old Nov 15, 2009 | 05:44 PM
ls1chris's Avatar
same here i tried every way to get a new sig pic but no luck.Tried everything i know how and still nothing but a blank canvas
Old Nov 16, 2009 | 04:55 PM
davered00ss's Avatar
Moderator
I'm getting the same thing. I will check into it.
Old Nov 16, 2009 | 06:02 PM
chrisholland's Avatar
behold. u kan haz sigs now.
Old Nov 16, 2009 | 08:47 PM
n2ocamaro's Avatar
Solved! Thanks!
Old Nov 16, 2009 | 08:58 PM
cabotgsxr's Avatar
i still cant do it?
Old Nov 16, 2009 | 09:10 PM
JeremyT's Avatar
Worked fine for me when I tested it. Make sure you're aware and following the rules that apply to signatures - one of them being the image must be hosted on the ls1tech.com website and not externally as many other websites would.
What errors are you receiving? Do you have the sigpic tag is in the signature?
Originally Posted by cabotgsxr
i still cant do it?
Old Nov 17, 2009 | 03:10 AM
studderin's Avatar
Old Nov 17, 2009 | 05:58 PM
cabotgsxr's Avatar
could someone walk me thought this step-by-step because apparently this is the first time i have ever used a computer?
Old Nov 17, 2009 | 06:28 PM
JeremyT's Avatar
Go to UserCP: https://ls1tech.com/forums/usercp.php
Click on Edit Signature: https://ls1tech.com/forums/profile.php?do=editsignature
If the signature picture is on your HD, use the "Option 2 - Upload Image From Your Computer" box by clicking on the Browse button and finding the file on your HD. Select the file and click OK and then then Upload button. You should be then returned to the Edit Signature page and should see the signature picture below the message box. Next to the signature picture you will see a "Insert Signature Picture" link. Click on it. It will then insert the Sigpic tags into the message box above (your signature box). Then click on Save Signature button.
If the signature picture is hosted elsewhere online, use the
"Option 1 - Enter the URL to the Image on Another Website" and enter the URL for the image. You can find the URL by right-click on an image and selecting Properties and copying the Address/Location (depends on the browser you're using). Copy/Paste the URL into the box. Click on Save signature button. You should be then returned to the Edit Signature page and should see the signature picture below the message box. Next to the signature picture you will see a "Insert Signature Picture" link. Click on it. It will then insert the Sigpic tags into the message box above (your signature box). Then click on Save Signature button.
