User Support & Resources Account Problems | Questions | Suggestions
Sig pic with every post?
Old Jul 29, 2010 | 11:10 AM
barkingspud's Avatar
Default Sig pic with every post?
Is there a way I can configure my profile to only use my sig pic once instead of throwing it out there with every post I make?
Old Jul 29, 2010 | 05:37 PM
JeremyT's Avatar
There is no such setting with the stock vBulletin forum. It would require a plugin install (3rd party software) to control signatures per thread.
Old Jul 29, 2010 | 05:45 PM
Ah...Ok...Thanks
Old Jul 29, 2010 | 09:16 PM
Sharpe's Avatar
...but, there is a "Show your signature" check box in the Miscellaneous Options below every post so you can un-check it. I always forget to use it.
I would love for a plugin to be installed that made it so that sigs were only showed once per page. That would be great. But, not that big of a deal, either.
Old Jul 29, 2010 | 11:12 PM
JeremyT's Avatar
A very easy template modification that use to be done before such a plugin existed, was to remove the default checkmark in the Show Signature option. So if a user wanted to show their signature, they would always have to manually select the checkbox. This was the opposite from stock as stock you have to manually disable the checkmark if you don't want the signature posted.
Today, there's several plugins that do a better job.
Old Jul 29, 2010 | 11:31 PM
Duh...I can't say I've ever actually saw that before now. That will work just fine. Thanks!
