Trader Rating
Rating a Member:
1) To rate a member on a transaction that took place on LS1Tech, you must first find the thread that the transaction had originated from.
2) Once you have found the thread that the transaction had originated from, click the value in the brackets for the "Trader Rating: (X)", which appears in the left side of the screen of the post of the member you are going to rate.
3) You are now viewing the member's iTrader feedback. Click on the link "Submit Feedback For (member's name here)", as the illustration below shows:
You are now viewing the submission form that will be used to submit the feedback for the member you are rating:
4 A) From the drop-down menu, select the party you were in the transaction (Buyer or Seller)
4 B) From the drop-down menu, select the rating you wish to give for the transaction (Positive, Negative or Neutral)
4 C) In the comment box, enter in a brief description of the transaction, such as comments like "Great communication", "Smooth transaction", "Would deal with again", etc.
4 D) In the "Deal thread URL", enter the URL of the thread that the transaction had originated from. The URL is the web address for the thread that the transaction had originated from.
To find the URL/Address of the thread that transaction had originated from, open a new browser window/tab to find the thread that the transaction had originated from.
Once you have found the thread, find the URL/Address in your browser's address field (top section of your browser) and right-click your mouse over the address, select "select all", then select "copy". The address/URL of the thread should now be copied to your operating system's clipboard.
Next, go back to the window/tab in your browser that you were using to enter the feedback submission form. Right-click your mouse inside the "Deal thread URL" and select "paste". The address/URL of the thread should now be posted in the "Deal thread URL".
4 E) Add any comments you wish to include, that are relevant, to the transaction in the "additional comments" section.
4 F) Click on the Submit Reply button to post the rating.
