can't upload pics I have tried to upload pics, gives me the internet explorer screen, click the line for previous page it says I'm not authorized ?? |
Well it appears you were trying to attach to the following post of yours: https://ls1tech.com/forums/16692381-post8.html Please copy/paste the exact error you received, and if possible, a screen capture of the issue. I checked your account and you have normal permissions to attach and your account shows you've attached in the past few years. |
error 505 website is not permitting? I even deleted my previous attachments, thinking I might have been over limit. |
What browser are you using? I was able to edit your post and make an attachment: https://ls1tech.com/forums/conversio...l#post16692381 |
latest internet explorer. I did a system restore thinking maybe my settings had been changed with a download. still doesn't work. I tried posting an another forum, it works there. http://www.s10forum.com/forum/f213/b...5/#post7942248 |
I've not heard any similar issues. See the Microsoft article, linked below, which suggests that this could be caused by 3rd party software interfering with your IE or wrong settings: http://support.microsoft.com/kb/811262 |
I have wndows7 home premium os. why doesn't it effect other websites? went through the described fix, same results. http://windows.microsoft.com/en-US/w...es-HTTP-errors |
That article applies more than just XP. It appears that others are able to use the Attachment feature and I was able to add an attachment to your post. It appears to possibly be something on your side and may be a 3rd party software installed and interfering as the Microsoft article suggests. |
I tried all the fixes, still does not work. I have uploaded pics on syty.net, s-10 forum, performance trucks today with no problem???? |
PT and LS1Tech share resources on the server side. If it works on PT but not LS1Tech then, to me, that makes me suspect there is something local (on your side) that is interfering with the process. I understand that you said the issue doesn't occur on other sites. However, I have not seen others report the same issue and the logs show several attachments uploaded at any given time. Meaning that others are able to use the attachment system and so it doesn't appear to be an obvious issue on the server side to make it a global issue for all members to experience the issue. I'll do some more poking, but at this time, I can only suggest you try a different computer or maybe another browser.
Originally Posted by sparkwirez06
(Post 16703671)
it worked, i didn't change anything and it uploaded pics:eek2: |
just try to sign out and then again log in it occurs many times that the pics dosent gets uploaded as you do this thing i think that is really going to work for you |
| All times are GMT -5. The time now is 01:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
