name change?
2) Fill out a petition. Most states require you to fill out a petition (or application) listing your reasons for wanting to change your name. Remember that this will be submitted to a judge, so make sure it explains your reasoning completely and correctly.
3) Have your petition notarized or signed by a court clerk.
4) Make copies for your own records.
5) File your petition with your local civil court. Visit your local civil court in person to file the petition with a clerk. He or she will give you a court date, which you should make sure you can attend.
6) Attend your hearing. Most name-change hearings are fairly straightforward. The judge might have a few questions for you, though. Try to answer clearly and honestly.
7) Get a copy of your name change court order. If the judge approves your request, you'll be granted a name change court order, probably given to you by your local civil court clerk. Make a copy for your records.
8) Put an ad in the newspaper announcing your name change (optional). This gives the public a chance to object to your name change if, say, you owe debt under your current name. Some states allow you to simply post in a public place such as a designated bulletin board at the courthouse.
