User Support & Resources Account Problems | Questions | Suggestions
Forum question
Old Oct 26, 2021 | 06:22 PM
02ws6kid's Avatar
Default Forum question
Hello guys, I was wondering which thread topic would be the correct to post in if I wanted to share my upcoming project and ask for any advice someone might have. Thank you
Old Oct 27, 2021 | 01:19 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Depends on the project.
Old Oct 27, 2021 | 02:19 AM
02ws6kid's Avatar
It will be a rear end rebuild/upgrade, as well as suspension upgrades. Should I make two different threads ? Thank you
Old Oct 27, 2021 | 01:24 PM
RPM WS6's Avatar
"Build threads" (an ongoing chronicle of multiple projects on the same vehicle) are typically posted in the applicable vehicle specific section (e.g. Camaro section, Firebird section, etc.) Assuming your username and avatar are of the car in question, then the correct section for such a build thread would be here: https://ls1tech.com/forums/pontiac-f...-1967-2002-73/
If these are just individual projects that will be separate and treated as such, then you could create two different threads for the respective projects; rear end rebuild would belong in Gears & Axles section while the suspension upgrades would belong in Suspension & Brakes.
Hope that helps.
Old Oct 27, 2021 | 01:30 PM
02ws6kid's Avatar
Hope that helps.
Thank you for your help
