User Support & Resources Account Problems | Questions | Suggestions
"Select All" Preferences
Old Mar 15, 2025 | 10:57 PM
BBPanel's Avatar
Veteran: Marine Corps
Default "Select All" Preferences
When I go to "Edit your LS1Live Preferences" the select all/deselect all box is not checked and doing so and saving the setting apparently doesn't work. If I press "new posts" I get maybe two. What am I doing wrong?
Old Mar 16, 2025 | 06:31 PM
JeremyT's Avatar
It works correctly for me. This sounds like a browser issue, since that function uses javascript, which your browser supposed to execute correctly.
Try a different browser or disable your extensions. Assuming your using the full-view desktop version?
Old Mar 16, 2025 | 07:14 PM
BBPanel's Avatar
Turn off all extensions (3) in FF has no effect. Open Forum in Edge and it works properly. Just out of the blue it doesn't work!
Old Mar 17, 2025 | 08:16 AM
BBPanel's Avatar
I give up - can my account be reset or something?
Old Mar 17, 2025 | 01:28 PM
JeremyT's Avatar
There is no reset feature. It's not with the account, however, I have enabled all forums for your account.
I use Firefox myself, and the feature works. So there is something wrong with your browser not allowing the javascript to function.
Old Mar 17, 2025 | 01:33 PM
BBPanel's Avatar
Regardless of what I set and save and come back to this page it looks like this.
Old Mar 17, 2025 | 01:49 PM
JeremyT's Avatar
I think I figured out your issue. Under Miscellaneous Options, Subscribed threads only was selected and that appears to override regardless of what's checked in the list above. I removed it from your account. Does that fix your issue?
Old Mar 17, 2025 | 02:55 PM
BBPanel's Avatar
Looks like I'm ok now - appreciate the time you took to correct it.
 Michael S. Palmer
