User Support & Resources Account Problems | Questions | Suggestions
How do u post pics?
Old Apr 15, 2006 | 08:55 PM
n20stroker's Avatar
Default How do u post pics?
Need help postind dyno sheet, cannt do it says file is to big.
Old Apr 15, 2006 | 11:26 PM
~JOSHUA's Avatar
I don't know about resizing, but I know if you find a photo you want to post...
You right click your mouse on it, highlight the "properties" section then right click, & choose copy.
Then you go to the thread and put the cursor in the box to post a reply...
Left click the button and right click in the box that appears, & choose "paste" in the box.
I don't know if you simply had a resize question or if you needed this extra help... Good luck! ~Joshua
Old Apr 16, 2006 | 09:31 AM
n20stroker's Avatar
thanks for the help.
Old Apr 16, 2006 | 11:12 AM
cyphur's Avatar
the other way is host the image online, get the direct link for the image you want to post up, and then use the 'img' tags. it looks like this:
Code:
 {img}www.addressofyourpicture.com/filename.extension{/img}
except instead of the { & } brackets, use the [ & ] brackets.
where i put filename.extension, you would put in the name of your file, ie car.jpg. always try to save pictures in JPEG formats, which are identified by the .jpg extension. smaller and still fairly high quality.
