CFM/RPM Thread
Can someone help me find it? I'm almost sure it was a sticky, and I want to say it was in the Gen IV Internal section ('cause I remember thinking where it was didn't make sense where it was, since it was discussing an LS1). However, I'd consider it advanced performance, moreso. I checked there, it wasn't moved, and I didn't turn up anything with a few searches.
Help!
If you can't find it with a search, the thread may have been deleted or moved to lockdown for some reason. Do you remember the title of the thread?
Try searching in all open forums, rather then just one or two sections. That way, if someone moved it to another section you can cover them all with one search.
I didn't read the whole thread, but it was pretty civil, so I doubt it'd be deleted or locked. It was a pretty big thread though, I was only on page seven.
Err, nevermind.
Halfway through typing this, I remembered that QuietTahoe posted quite a bit in that thread, and he only had 114ish posts. So I looked up his name and found it:https://ls1tech.com/forums/advanced-engineering-tech/396087-camshaft-discussion-cfm-requirements-rpm.html
Thanks
