2000 SS Custom Rear Mount Turbo, Custom 8Pt Cage Reason for selling: I'll post this here to hopefully cut down on the chatter in the thread. I lost the motor in January while just driving 65-70mph normally and running errands (made a short pull a few miles previously without incident before it let go). Looks like the #3 connecting rod failed near the wrist pin which of course munched up lots of stuff. Rods were SBC Eagle I-beams because in 2005 LS1 parts were too expensive for me. The car was only supposed to make about 750 crank HP. My friend Jon (1320 on here) offered to build me a forged 346 for $4k installed which is a killer deal, but it's $4k I don't want to spend. I've been working 32hrs/wk for the last 2 years and just got dropped down to 30hrs/wk. There is not much of a car scene here any more and I rarely drove the car the last 2 years because I had no where to go except for weekend errands, grocery store, etc. This is my dream car, but I no longer have the motivation and think I'm just growing out of the hobby. http://dynamic.opticalanarchy.com:80.../SS/cf_ss1.jpg http://dynamic.opticalanarchy.com:8080/zombie/SS/ <--- lots and lots of pics of the car and fabrication that went into it. http://dynamic.opticalanarchy.com:80.../SS/cf_ss2.jpg I will leave this up for a while to try and sell everything whole. Eventually I'll part it out in a separate thread and sell the chassis or have the junk yard pick it up if there is no interest. Do not PM me about individual parts. if you do...:D $7K gets you the roller (install your own engine/trans/electronics) $10k gets you everything listed, just needs new engine. $12k gets you everything as is (all electronics, injectors, Aeroforce Scan Gauge, megasquirt II, stock ecu which runs everything else because I only have the megasquirt doing fuel, wideband, motor accessories etc) $14k get you everything + my brand new 1700HP in tank fuel system which hasn't been installed. All you have to do is drop in a new long block and fire it up, re-tune for your location/fuel. Motor was a 370 iron block with 317 heads. Car ran a best of 10.001 @ 135.2 with a 1.49 60' at the top of 2nd gear. Has at least 50 mid to low 10 sec passes that I have slips for. Motor that died was built from junk parts and lasted 20k miles at 15psi. I built this as a fun street car that went to the track for fun. I can't stand driving a race car so this is about as extreme as I was willing to go because I like comfort. My car was probably one of the best running rear mount setups around. Here is some video of how it drove and spooled. http://www.streetfire.net/video/new-...ipi_739094.htm You can search ZombieSS to see several other videos of the car on streetfire and youtube. Turbo Setup: Intercooler 4" ebay Piping: 3" from turbo to intake. One piece from turbo I/C, on piece from I/C to throttle body. Exhaust: manifolds ceramic coated, exhaust pipe is 1 piece 3" from manifold to turbo, ceramic coated and fiberglass wrapped. Turbo: Forced Inductions SX80 which is a Borg Warner S380 80mm compressor with race cover. 87mm Exhaust wheel with 1.25 A/R divided turbine housing with quick spool valve. Cracking pressure of 4 psi fully open by 10 psi. Wastegate: 42mm Tial BOV: none Front Suspension: Strange dual adjustable shocks 325lb springs Rear Suspension: Comp Engineering 3 way adjustable Short body mount torque arm (unsure of brand) Wheels Tires: Rear: 15x10" pro stars with MT Street Radial with tread left, 1yr old Front 15x4" jegs stars with tires (should probably be changed, kinda old) stock studs. Trans: TCI SFI Flex plate PTS 3600 9.5" torque converter spec'd by Dusty Bradford. Stalls to 3600 rpms on the trans brake with no boost, will stall to 5200 with 14psi. Nice and tight for daily driving, with 2.75 gears I never had to exceed 2500 rpms and will move at 800 rpm idle if your foot isn't on the brake. Transmission is a Th400 built by Carl Rossler. Has electronic speedo setup, trans brake, reverse manual valve body (you must shift manually), 2nd gear intermediate band was kept so there is engine braking in 2nd gear (safe to downshift from 3rd to 2nd while not under power). Trans is rated to 1200 torque. Needs input shaft if you want more. Shifter is a Hurst ratchet shifter forget what model but it's lots of fun to drive. Engine: It's blown up, you don't want it Rear end: Moser 9" 2.75 gears full spool 31 spline axles ARP 3" studs Body: 2000 Camaro SS, straight body, decent paint shows normal wear. Carbon fiber SS hood (can be made functional), carbon fiber SS spoiler, rear hatch painted black to complete 2 tone look. Aluminum grill painted black. Wheel well plastic trimmed to fit 28" tires, bump stops removed and massaged. 8 point custom cage with removeable swingouts. Cage is mostly hidden by body panels and head liner (see pics for better explination). Should be certifiable (built to NHRA specs) but I don't race so I refuse to pay them the extortion money they want. Completely safe on the street and won't kill you in an minor accident like a normal cage would. 6 point belts just installed 6 months ago still in cert. A pillar 2 guage pod. Interior is mostly complete, T-tops can still be removed with tools, full carpet and sound deadening. A/C still works. Radio is dead Cruise control doesn't work, neither does traction control or ABS Fuel system: Dual in tank Walbro 255 high pressures Stock Returnless system I think that's most of it. Call if you have any questions. Car is in Las Vegas. 8am-11pm PST any day. Call if you want to talk about price / options. 702-328-5339 Jeremy |
Hi, your streetfire.net link does not work |
Originally Posted by Croman
(Post 14818371)
ok thanks zombie you said you hate race cars....lol so do I!! when you are driving at 55mph, what is the rpms at?? thanks |
(Post 14820373)
Hey Zombie, sorry to see you getting rid of this. PM me a price for it all minus the blown engine obviously, the turbo kit, and the extra 1700hp fuel system. Basically car as is minus ur blown engine and turbo kit. Thanks sir! :cheers: |
Bump 5chars |
Still for sale, probably going to start parting it out soon. |
one last bump, think it's almost time to part this thing out. I hate to see the shell go to waste but it won't even be a roller when parted. |
I just realized.... Bump by the way for a bad ass car... you managed 10s!!!! with 2.75 gears!! you sir, again, are my hero! makes me feel better that im still on my stock rearend while slowly upgrading my car with 2.73s |
When your ready to start parting out, i might be interested in some of your parts. Im doing my own custom rear mount. trying to get pieces to germany are pain in the butt somtimes. Shame the motor went out when it did. Still a Badass ride. |
© 2024 MH Sub I, LLC dba Internet Brands
