*SOLD* 1999 Pontiac Trans Am - LS1/T56/12 bolt
Year: 1999
Make: Pontiac
Model: Firebird
Price: $8500
Mileage: 88000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Beige
Transmission: Manual
Drivetrain: Rear Wheel Drive
1999 Trans Am with 88k miles, LS1/T56/12 bolt
Engine:
-Cam
-LS6 intake
-Fast Toys Ram Air
-SLP lid w/ K&N filter
-SLP headers w/ exhaust shop duals
Transmission:
-I was told it has a Tick Level 2 T56, but never got any paper with it
-Tick master cylinder
-Centerforce clutch
-Aftermarket shifter w/ short stick
Suspension:
-UMI torque arm w/ relocation crossmember
-Adjustable panhard bar
-Tubular LCA's
-3-point subframe connectors welded on
-Bilstein shocks
-BMR lowering springs
-Moser 12 bolt w/ 3.73 gears, Moser differential cover, posi unit
Wheels:
-15x3.75 Dark Stars w/ Mickey Thompson Sportsman tires
-15x10 Dark Stars w/ Mickey Thompson ET Streets
Exterior:
-OEM WS6 hood
Other:
-Viper alarm system
Bad:
-typical rock chips on front bumper & some slight spider cracking on one side (not as bad as it sounds)
-dime sized blemish on edge of driver's door
-exhaust should be redone as the duals are pretty shoddy
-still has the stock driveshaft, will need upgraded if you plan on launching hard
-no door keys or stock key fob
-tach is currently not working (I believe it is the cam position sensor, I may end up fixing this issue)
-previous owner broke a driveshaft, which also broke one of the e-brake cables
I am being up front about every issue that I know about. This car is super clean on the inside and out, you will not be dissapointed. The car is located in Brazil, Indiana. I am 100% firm on the price, but am open to trade offers.
