Western Members CA, AZ, NV, UT, CO, NM, HI
Help!
Old Nov 23, 2008 | 06:26 PM
impstrz28's Avatar
Default Help!
So I installed my LS7 clutch bled it and its not working. i press the pedal and i cant put my car in gear. i took it appart made sure every thing was on right and put a spacer behind the slave cylinder put everything back to gether and still nothing. So to get it home i had to start it in gear and give it gas so it could start rolling. i was able to get it home that way. so what can i do to make it work? would and adjustible master cylinder help? some one please help!!! thanks.
Old Nov 23, 2008 | 07:07 PM
djsanchez2's Avatar
wierd hope you figure it out. Had zero problems with mine, and i didn't even use the spacer, car didn't have one.
Old Nov 23, 2008 | 07:08 PM
yungepjr's Avatar
i had the same problem. check your fluid. i have the ls7 clutch and it comes with brand new fluid i beleive but yea that was my problem. jus tryna help. good luck
Old Nov 23, 2008 | 07:11 PM
impstrz28's Avatar
I went through a whole bottle of brake fluid bleeding it. think i should bleed it more?
Old Nov 23, 2008 | 07:13 PM
djsanchez2's Avatar
Did the color of the fluid coming out the bleeder screw lighten up alot? If it's still dirty or dark, put another 1/2-1 bottle through it.
Old Nov 23, 2008 | 07:26 PM
impstrz28's Avatar
To be honest i didnt really pay attention to that. Think maybe i need to bleed it more?
Old Nov 23, 2008 | 07:35 PM
MrElectric03's Avatar
Keep bleeding...when I did mine I bled it forever and it would just barely go into gear,then I bled it some more and eventually starting working.
Old Nov 23, 2008 | 10:01 PM
impstrz28's Avatar
Any more suggestions?
 Michael S. Palmer
Old Nov 23, 2008 | 10:09 PM
P-DOG's Avatar
I spent hour's bleeding my clutch that did not work I put a SHIM in and work great
Old Nov 24, 2008 | 09:23 AM
ss.slp.ls1's Avatar
He said he did use the shim.
It has something to do with your hydraulics/fluid. If you are using your same hydraulics that had no issues before the swap then it has to be something to do with the fluid. I'd hook up a mighty vac to your reservoir and try to bleed it that way. Lots of bubbles should come out.
Old Nov 24, 2008 | 10:09 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i had this problem before, i used a mityvac to bleed the system with a remote bleeder, i put the clutch pedal to the floor and bleed it on the floor, for some reason it worked that way, and i have no idea how or why it did, but it worked
Old Nov 24, 2008 | 12:37 PM
impstrz28's Avatar
Where can i get a remote bleeder and a mityvac?
Old Nov 24, 2008 | 12:41 PM
ss.slp.ls1's Avatar
You can get a mighty vac at AZ. I would try bleeding it at the reservoir first.
