Brake Pads ??????????
I was thinking about ceramics since the fronts turn black in about 2 days, but I'm not sure about mixing the ceramics on front with the semi-metallic on back. Thoughts?
Here is what Advanced Auto Parts has right now. Thoughts on your picks?
Wearever Gold BRAKE PADS GOLD WREVR
Pad; Semi-Metallic; OE Replacement
Warranty: LTD LIFETIME REPL
Wearever Silver Wearever Silver
Friction Master BRAKE PADS CERAMIC FRTMS
CERAMIC BRAKE PADS
Warranty: 2YR REPL
Akebono ProACT Ceramic Brake Pads
Brake Pads: Front; Proact Ultra Premium Ceramic Pad; Oe Ceramic
Warranty: Ltd Lifetime Warranty Excludes
O'Reilly Brake Best Select Brake Pads
Brake Pads: Front; 1 Per Vehicle Quantity
Performance Friction Carbon Metallic Brake Pads
Carbon Metallic Brake Pads: Front Only
Carbon Metallic Brake Pads: Front; With Disc Front Brakes; With Disc Rear Brakes
Raybestos Service Grade Brake Pads
Brake Pad Set: Service Grade; Front; Ceramic; Originally Equipped With Ceramic; Recommended Replacement; 1 Per Car
Raybestos Raymold Brake Pads
Brake Pad Set: Raymold Semi Metallic; Front; OE Ceramic
Warranty: Ltd 2 Year Warranty Excludes W
Raybestos Professional Grade Ceramic Brake Pads
Brake Pad Set: Professional Grade; Front; Ceramic; Originally Equipped With Ceramic; Recommended Replacement; 1 Per Car
Raybestos Super Stop Brake Pads
Brake Pad Set: Super Stop; Front; Semi-Metallic; Originally Equipped With Ceramic; 1 Per Car
Raybestos Quiet Stop Brake Pads
Brake Pad Set: Quiet Stop; Front; Ceramic; Originally Equipped With Ceramic; Recommended Replacement; 1 Per Car
Raybestos BruteStop Brake Pads
Brake Pad Set: Brutestop; Front; Semi-Metallic; Originally Equipped With Ceramic; 1 Per Car
