Western Members CA, AZ, NV, UT, CO, NM, HI
My issue
Old Dec 28, 2008 | 12:44 AM
james562's Avatar
If you spend 800-900 on a 10 bolt you've been fucked big time...
I picked up a 3.42 rear for 100.00 complete from end to end $20 of Black POR15 and it looks clean as ****.
There are plenty of deals on stock rears for $100-300... Dont blow a grand on a stock rear...
Old Dec 28, 2008 | 12:22 PM
SUCK MY SS's Avatar
whoa dude i just saw this thread....i hope you didnt order any parts yet for that ten bolt...if you did id return them immediately...just pick up a good condition used rear end...much less headache of breaking one of those than a polished up turd people call a "built ten bolt"... they just dont last on these cars...
Old Dec 28, 2008 | 01:17 PM
hlaalu's Avatar
i saw a 9" on ebay for 900 bucks
Old Dec 28, 2008 | 03:02 PM
LS1Adam84's Avatar
Hahaha no worries guys I posted on the last page that I was going to be getting a rear instead of building my ten bolt. Anyone need a ten bolt rear housing as the carrier may need to be replaced axles should be good.
Old Dec 28, 2008 | 03:05 PM
LS1Adam84's Avatar
Originally Posted by ae13291
i really dont think the torsen is going to make that noise. at least open up the rear and check it out! it could be that there is no oil in the rear
3a. The torsens seem to wear out quicker whether you race or not. Tell-tale signs of a fading torsen are ratcheting/clunking noises when turning/low speeds/etc. If your torsen does break, you can replace it with another, or pick up an aftermarket carrier.
This was taken from the axles and gears section.
Old Dec 28, 2008 | 08:20 PM
Dan's Avatar
Dan
I beat the **** out of my car(98 T/A), probably have 300 passes on my "stock" 10 bolt with 3.42 Gears..It whines & I might have a posi issue but I have had the car since 02. If you are not going to run the strip you are probably ok to spend the $900 or get a cheap used one.
Old Dec 28, 2008 | 08:22 PM
nordy racer's Avatar
let the money pit begin....
Old Dec 28, 2008 | 08:31 PM
LS1Adam84's Avatar
hahaha thats what you think mike nahh for now just a cheap replacement then a couple years a 12 bolt goes in.
