Western Members CA, AZ, NV, UT, CO, NM, HI
tranny woes
Old Feb 6, 2009 | 11:34 PM
carbonfiberbird's Avatar
Thumbs down tranny woes
My tranny grinds when I shift into fifth, it was rebuilt about 8 months ago. I'm gonna change my fluid to normal atf fluid, see if anything changes cuz now I have amsoil synthetic, its always been notchy, so hopefully thats it. Any thoughts or suggestions? Anything would help
Old Feb 7, 2009 | 03:27 AM
Soul TKR's Avatar
sometimes your clutch hydraulics can be a culprit in grinding...
Old Feb 7, 2009 | 04:00 AM
Wicked94Z's Avatar
yea my understanding was that anything synthetic in your tranny or rearend is a no-go, too slippery for the syncros to work properly.
Old Feb 7, 2009 | 04:32 AM
I think I'm gonna try the drill mod too, if I have time I'll change the fluid tomorrow and let you guys know what happens
Old Feb 7, 2009 | 11:57 AM
Looks like the tranny's coming out, changed it to regular ATF fluid and it shifts alot better but fifth has the same problem. I actually had Mobile 1 synthetic fluid in it, not Amsoil. I hope its under warranty.
Old Feb 7, 2009 | 02:05 PM
haighter's Avatar
You could of damaged the 5-6 pads and blocker ring for 5th. The stock pads are made of plastic and the stock blocker ring is made with a paper backing. We replace the plastic pads with bronz ones and the blocker rings with carbon lined ones. Changing the fluid will not fix the problem if it is synchro related. Give us a call at CMS for pricing.
Old Feb 7, 2009 | 02:56 PM
Thanks man, I think it is synchro related cuz it'll grind 4-5 and I cant down shift form 6-5. I appreciate it but the trans. is still under warranty, plus we have a shop. Thanks tho
Old Feb 7, 2009 | 09:21 PM
ae13291's Avatar
i had a third grinding issue, i did the drill mod dot 4 fluid and 4 quarts of syncromesh fluid. now it rarely grinds
