Western Members CA, AZ, NV, UT, CO, NM, HI
i want headers!
Old Mar 17, 2009 | 05:32 PM
KILLER-LS1's Avatar
Default i want headers!
hey guys, dont ask why but i will be getting either a set of edelbrock or hedman headers for my car. I just have no clue as to the edelbrock long tubes... does anybody have any experience with these??
Old Mar 17, 2009 | 05:39 PM
02NBMWS6's Avatar
Yes. They are a very good header. They are on my 403 and they kick ***. Best budget header by a looong shot
Old Mar 17, 2009 | 05:44 PM
KILLER-LS1's Avatar
youre talking about the edelbrock? is that the one with the slip on collector? and what did you use as a y-pipe??
Old Mar 17, 2009 | 05:49 PM
02NBMWS6's Avatar
Yes, the Edelbrock long tubes. With the slip on collector. The ones with the collector already welded on have a shitty collector just like pacesetter, tsp, etc. The collector makes the difference.
I went to CMS and had them fabricate a custom y pipe to fit my car using a Flowmaster y- merge. This is FAR better performance wise than any affordable y pipe setup you can buy, plus it's tailor fitted to my car and I had the choice of what size outlet piping I wanted to use. I opted for 3.5" personally. This cost me roughly the same as an "off the shelf" y pipe would have.
This setup will make great power. It was part of my 133mph 346 and my new setup.
Old Mar 17, 2009 | 05:52 PM
02NBMWS6's Avatar
Just recently I damaged my old set of Edelbrocks and replaced them with another set. This is a testament to my belief in them. On the new set, I had them high temp powdercoated after the collectors were welded on and they look great.
Old Mar 17, 2009 | 06:13 PM
KILLER-LS1's Avatar
ok, are you running cats on your y-pipe? if so, what kind? i get a really good deal over at edelbrock but im not sure if i want the longtubes over the shorties because it seems like a lot of work. i can weld and fabricate though, so it doesnt really sound like a problem. the guys i know that work there were kinda skeptical of me putting it on my DD...
Old Mar 17, 2009 | 06:16 PM
02NBMWS6's Avatar
Don't be skeptical at all. Once the collectors are welded on (which takes all of 10 minutes) there is no difference between these and any other headers. You seriously just hammer the collector on and tack it in a few places or use the brackets they send. I just welded mine around. Ive been running them on my daily driven cars for two years now. They don't hang low either, which is another common problem for LTs. I'd do LTs or no headers at all fwiw.
I'm not currently running cats, but I have considered it before. I have room under there
Old Mar 17, 2009 | 06:26 PM
KILLER-LS1's Avatar
perhaps you could pm me where you get your smog? thanks for all the help btw..
Old Mar 17, 2009 | 07:50 PM
MrElectric03's Avatar
I have seen Wills car and noticed his headers, they look great and made great power, and those are the older ones, the new ones he had coated must look pretty sweet.
Like he said, if you are not doing longtubes dont go with shorties. Ive had the edelbrock shorties and it was a waste. Although im pretty happy with my 1 3/4" ARHs if I were to step up to 1 7/8" id probably go with the edelbrock LTs.
Old Mar 17, 2009 | 10:48 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
edelbrock headers are great headers, they make the most power on a 346 that i have seen. of course these are the slip-on merge collectors
Old Mar 17, 2009 | 10:53 PM
KILLER-LS1's Avatar
what do you think the odds would be at passing the sniffer only if i welded in carb legal cats as close to the collector as possible? i would run a true dual dumped with this setup
Old Mar 17, 2009 | 11:04 PM
KILLER-LS1's Avatar
ok so is it the edelbrock 65703? and im assuming i would just install the collector on all the way and weld it all the way around. im not looking to change the length or anything right? thanks again everyone!
Old Mar 18, 2009 | 12:54 AM
If you want to pass the sniffer id have Ryne tune it, a 224 cam shouldnt have a problem as long as you are runnning cats. I havent had to weld them personally but Ryne would be the guy to ask, they also make great fitting Y pipes and exhausts, my 4" magnaflow setup they made for me is awesome!
Old Mar 18, 2009 | 10:52 AM
02NBMWS6's Avatar
Yes, 65703. Yes, just bang them on with a piece of wood as far as you can and then you can tack them, weld all the way around, or use the brackets that they supply. No, no reason to change the length. Youre welcome
Old Mar 18, 2009 | 11:09 AM
nevrlift13's Avatar
i have edelbrocks also and LOVE them...
Old Mar 18, 2009 | 11:22 AM
KILLER-LS1's Avatar
Ok great, I'm definitely going with the edel headers. Now I just have to figure out what I want behind them! I'm definitely going dual but I'm thinking if I should go with some high flow cats or not? I basically would only put them on if I thought I could pass the sniffer part of the test. Otherwise I'd do some bullets. U guys think I should worry about the smell w/ no cats?
Old Mar 18, 2009 | 11:23 AM
02NBMWS6's Avatar
You can pass the sniffer with the cats. The smell without them won't be that bad if you decide to leave them off though.
Old Mar 19, 2009 | 02:50 AM
01SuperSport's Avatar
Man I love the smell of gas Just go no cats with the tsp true dual set up. You'll find a smog shop to pass your car under the table just ask around
