Western Members CA, AZ, NV, UT, CO, NM, HI
i need help
Old Jun 5, 2009 | 03:03 PM
patmedina's Avatar
Default i need help
Ok today I finished my exhaust system in my 01 ta. I did hooker LTs with a three inch y pipe and magnaflow. There is no cats and I got the o2 extensions installed. Everything is done but my car is driving like **** and has a miss fire. Check engine light is on. What do I do?
Old Jun 5, 2009 | 03:20 PM
SUCK MY SS's Avatar
scan the DTCs and see what the PCM will tell you...
double check all your plugs... make sure you didnt drop any and close the gap or crack the porcelain while installing them.. doube check the wires and assure that they are all intact and making a good connection...
check DTCs first... may be something simple you overlooked...
Old Jun 5, 2009 | 03:23 PM
LS1Adam84's Avatar
Did you get race headers, as in, are they non AIR? Also what did you fron O2 sensors look like when you pulled them out, or installed them back in?
Try this as well in the mean time, disconnect the battery completely both positive and negative terminals, let it sit for about 10 mins then go out reconnect and start it up and see whats happening.
Old Jun 5, 2009 | 03:50 PM
ss.slp.ls1's Avatar
You are not that far from me. I'll be happy to read your codes from you and help you figure out your problem.
