Western Members CA, AZ, NV, UT, CO, NM, HI
Any ideas with this issue ?
Old Jun 12, 2009 | 07:42 PM
Tapout97's Avatar
Unhappy Any ideas with this issue ?
The car has issues, when you start the car up and rev it to 2 k for example the car will drop down to 300 rpm or so and wanna die then it picks its self up .... when you drive the car and come to a stop it dies. Ive been having all these issues since putting on long tubes. Ive checked all the wires that i can check " im not a mechanic " and have not found anything burnt or dead. The car has a new pcm and tune , battery , electric water pump all within the last 3 weeks. The alt was checked at autozone and it passed.
why is my car dieing and running like chit. Could it be as simple as the IAC has gone out ?
any real help will be greatly appreciated thanks guys
Old Jun 12, 2009 | 08:29 PM
MrElectric03's Avatar
Is it OBD1 or OBD2? I forget if the 97s got the OBD2 or not. Is it throwing any codes? How fresh is the optispark?
S.R.J. is the LT1 guru.
Old Jun 12, 2009 | 08:30 PM
LS1Adam84's Avatar
EGR? is there any holes in the intake where something should go? sounds like a vacuum leak. Check everything again, if the car had EGR and now does not that might be your issue.
Old Jun 12, 2009 | 09:08 PM
Datzneat's Avatar
Mine has done this everyday for the last two years. No problem. lol
Old Jun 12, 2009 | 09:11 PM
Tapout97's Avatar
No egr.... its been tuned out. I just checked the IAC and ran the test looks like the IAC is dead..... vaccum leaks ? how do you check for them im not a mechanic so im still learning how to do my own work.
any help will be greaty appreciated !
Old Jun 12, 2009 | 11:01 PM
myslow92's Avatar
I say it needs a lil touch up tune.....had that problem in mine when it was running a bench top tune and after touched up in a couple spots it went away
Old Jun 12, 2009 | 11:16 PM
Tapout97's Avatar
i just bought a new PCM computer and just had it tuned at pcm4less.com
Old Jun 12, 2009 | 11:30 PM
myslow92's Avatar
so you did not have it tuned in car??????
ok my bench top tune was close.......close as anyone could get but had that exact issue....the wot was on safe side and ran great at track...actually showed a 12.7 af ratio through most of the pull .......but the weather in AZ sucks *** ....Do you have anyone that can just touch up some areas?
Old Jun 12, 2009 | 11:49 PM
Cross's Avatar
For the LTx guys those tunes are not as easy to get touched up. I have LT1Edit but even NicD hates looking at them.
Most with the tunes from Ion or PCM for less are close to dead on, but they always say hit the Dyno and send us the results for a free retune to those results.
On your car use starter fluid or carb cleaner and spray around the intake manifold see if you can get the car to suddenly rev up from it sucking in the fluid.
Next I would ask about your exhaust but you told me it was smoking so thats out. Unless it has changed has it changed?
You said your getting no codes and your a 97 right (Which reminds me for the one asking, 96-97 OBDII no one wants to touch tuning and I mean no one. 2 Years for the LT and everyone either tunes for the 95 and below or 98 and above LSx its like having the bastard child of the F-Body Community... oh wait thats the 93 and below ) I would say you need to data log it see what your sensors say esp at the time of this issue. Can you do that with what you have?
Ok now then I am going back to drinking and playing the Wii.
Old Jun 12, 2009 | 11:58 PM
myslow92's Avatar
then I would def see if you could data log something and get them to touch it up.
couple other ?? I have
does it only do it when colder engine temps mine did it only in a certain engine temp range also...was car was up to normal temp it was fine......that is why I say "touch up"
Old Jun 13, 2009 | 12:02 AM
Tapout97's Avatar
I did a new clutch and put in LT this febuary ....for the past month id say everytime i come to a stop it dies. or if i take a turn it dies. ????
if i turn the car on and let it idle and rev it up it drops way below 1000 rpm like its gonna die but doesnt ?
i have the IAC out and im gonna clean it tomorrow and re install everything and see if that helps if not i was thinking of buying a new one.
Old Jun 13, 2009 | 12:10 AM
Cross's Avatar
what happens if u disconnect the iac and start the car?
Old Jun 13, 2009 | 12:38 AM
hlaalu's Avatar
it really sounds like a vacuum leak like adam said. you can have them test for it at shop, all they do is use smoke and see if it gets sucked in somewhere, then charge you an assload.
ghetto style: light up some incense and see if it's getting sucked in anywhere other than your intake
Old Jun 13, 2009 | 12:47 AM
myslow92's Avatar
Originally Posted by hlaalu
ghetto style: Bong rips and blow it over the motor and see if it's getting in anywhere other than your intake
Didn't you mean it like this
Old Jun 13, 2009 | 12:52 AM
hlaalu's Avatar
Originally Posted by myslow92
didn't you mean it like this
lol!! :d
Old Jun 13, 2009 | 04:43 AM
m6ttop's Avatar
bad 02's??
