need help on a swap
youll have to reuse all the intake and injectors because they are truck specific.
also if you have some basic knowledge you can make your own standalone harness.
and good luck with the swap post pics
it should be able to get through smog with a small cam, but since youll have to take it to a referee, make sure your swapping in all the evap crap and you cant change out the heads. Also if it had a 4l65 behind it, it needs to be all hooked up and integrated into ur truck. you may need a electric to mechanical speedo converter and also the manifold and cats with 02 sensors have to remain in the same location. hopefully you can still scavenge some parts off that escalade. cali is a biatch for smog legal swaps
