Western Members CA, AZ, NV, UT, CO, NM, HI
LT1 tune results from CMS
Old Sep 20, 2009 | 02:23 AM
Wicked94Z's Avatar
Default LT1 tune results from CMS
Went down to CMS friday and worked with Ryne tuning my LT1 in open loop speed density. Motor specs....
388 ci
Ported AFR 210s
12.5 compression
Ported LT4 manifold
HR 24x/25x .62x 107lsa
Final numbers were 438rwhp and 450 rwtq on 100 unleaded. I've got either an ignition or valvetrain issue up top, i made peak hp at only 5600 rpm and the motor wouldnt pull much past 6000. Thanks to Ryne's tuning expertise we've got the A/F nailed down at 14.2-14.7 at cruising rpms and 12.8 at WOT. Much thanks to Ryne for working with my 10 year old laptop, and the crappy tuning and datalogging programs we have for the LT1. Driveability and gas mileage is a ton better than before, hell I can pull out from 1200 rpm in 6th gear with no bucking! I can't wait to get my issues worked out and see what it'll do at 7000 rpm on a 200 shot. So thanks again Ryne and CMS, definitely will be going with them for a rollcage, and further tuning of my combo.
Old Sep 20, 2009 | 02:29 AM
1 BLOWN V8's Avatar
Awesome, glad you got that beast dialed in better.
Old Sep 20, 2009 | 02:38 AM
millertime034's Avatar
I got my gto tuned from him last week. he's a good guy. very knowledgeable.
Old Sep 20, 2009 | 03:00 AM
Wicked94Z's Avatar
btw this was through one of his 4" exhaust setups. it did pick up 8 rwhp through the cutout, the big hooker maxflo keeps it pretty quiet but still restricts it a little bit.
Old Sep 20, 2009 | 06:30 AM
Wicked94Z's Avatar
Just talked with Bret Bauer... We had a little mis communication about the installed height on my PAC 1518s for the aggressive lobes I'm running. He's 100% positive it's valve float with the pressure I was running, so I'm ordering some k800s to throw in, 165# seat and 460# over the nose should do the trick live and learn.....
Old Sep 20, 2009 | 11:59 AM
01SOMSS!'s Avatar
good numbers.
Old Sep 20, 2009 | 01:21 PM
MrElectric03's Avatar
Nice, yea I was a little surprised that my combo topped out at 468 rwhp @ about 6250rpms with my 108 ICL, will probably go quite a bit higher once my 200 shot is hooked up.
Old Sep 20, 2009 | 03:37 PM
180ls1's Avatar
nice numbers for getting valve float, i dont know why but every time you post i have to stare at that man child in your avatar and it creeps me out every time.
Old Sep 20, 2009 | 04:40 PM
lt1 hawk's Avatar
great numbers! I always get a kick out of guys that insist that it is next to impossible to get numbers like that out of an LT1.
Question though, I take it you had to use your own software and laptop? I was under the impression that CMS did not have the gear to tune an LT1.
Old Sep 20, 2009 | 05:55 PM
Wicked94Z's Avatar
i brought my own software but the downloads are free
Old Sep 20, 2009 | 10:58 PM
383lt1impala's Avatar
lol me2 and cant wait to see some real numbers from it!!!
Old Sep 21, 2009 | 01:11 AM
ur jlus's Avatar
Congrats Stephen! Glad to see your back btw.
Old Sep 21, 2009 | 02:10 AM
ss.slp.ls1's Avatar
Post up if the new springs fixes your issues.
Old Sep 21, 2009 | 05:51 AM
Wicked94Z's Avatar
bret says the k800s will need replacing all the time with these lobes, so i guess scratch that. just to give you an idea of the ramp rates... my cam has less adv duration than your cc503. i might step up to the new PAC 1521s, manley nextecs, or bret says the 1518s installed at 1.74 will control the valve fine to 7200+. the problem i think lies in these heavy 2.08 intake valves.
Old Sep 21, 2009 | 11:10 AM
ss.slp.ls1's Avatar
Have your spring seats been machined down to get a 1.74" installed height? Or are you use offset locks?
Lighter vales are always nice.
Old Sep 21, 2009 | 11:24 AM
rzuff's Avatar
Nice numbers and a good sign for some big LT1 Power when you get everything worked out. Great talking with you the other day!
Old Sep 22, 2009 | 02:13 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
might want to look at some isky beehives as well..... of maybe even the new prc dual with a patriot lt1 retainer, those thinks have about damn near 500 open with a 1.800 install height. also talk to richard at west coast cylinder head, he might have some ideas as well
Old Sep 27, 2009 | 04:56 PM
domeztikviolentz's Avatar
is his prices reasonable i need a tune bad
Old Sep 27, 2009 | 08:49 PM
Wicked94Z's Avatar
ryne's a great tuner and his prices are very reasonable for what you're getting
