Western Members CA, AZ, NV, UT, CO, NM, HI
clutch ?
Old Dec 10, 2009 | 05:22 PM
snugans310's Avatar
Default clutch ?
who got the textrallia clutches for sale at a good price and what else would i need to get one of these on my 02 ss
Old Dec 10, 2009 | 05:28 PM
Smmokin01SS's Avatar
id buy a ls7 clutch its a bueno clutch and cheaper
Old Dec 10, 2009 | 05:33 PM
snugans310's Avatar
but i like to beat the **** out of my car its not a dd its a weekend warrior and street terrorizer lmao but it gets lots of racing abuse so i heard if u got the cash get the textrallia idk tho thats why i wanna know more
Old Dec 10, 2009 | 05:41 PM
ss.slp.ls1's Avatar
I installed one of these into my buddy's car and I liked it...
http://www.monsterclutches.com/gm.html
Old Dec 10, 2009 | 07:58 PM
Zeke34's Avatar
+1 For Monster Clutch.
Old Dec 10, 2009 | 08:01 PM
krazy4's Avatar
Seems like a lot of people like the monster clutches.
James has one in his 402 and that thing rips!
Old Dec 10, 2009 | 09:41 PM
MJs1FastSS's Avatar
monster stage 4 for me............
Old Dec 11, 2009 | 03:02 AM
Zeke34's Avatar
For the price they're very good clutches that can handle a good amount of power.
Old Dec 11, 2009 | 12:27 PM
lowerthanyou00's Avatar
u could replace the slave/carrier bearing assembly if u wanted just check it when u have it out. and check your pilot bearing ive seen these get torn up often in f bods. and check the fly wheel less ur throwing a new one on. also change the trans fluid.
Old Dec 11, 2009 | 03:06 PM
ss.slp.ls1's Avatar
Slave and pilot bearing should be replaced, no questions about it.
The Monster clutch kit should come with a new billet flywheel.
4 quarts of Dex/Merc or Mobil 1 synthetic ATF.
Old Dec 11, 2009 | 03:34 PM
180ls1's Avatar
does that drive ok on the street?
Old Dec 11, 2009 | 05:31 PM
MJs1FastSS's Avatar
18lbs light weight flywheel
its fine for my uses with all supporting mods ....... still need my 9" then I will be good to go
so if any has one FS let me know
Old Dec 11, 2009 | 09:28 PM
MrElectric03's Avatar
Id go with a RPS twin ceramic if I could do it over again, not happy with my Tex, too much chatter.
Old Dec 11, 2009 | 09:49 PM
Johnny@Xtreme_Trans's Avatar
I carry monster clutches
Old Dec 12, 2009 | 10:17 AM
droptopT/A's Avatar
huey! buy a ls7 clutch kit alot of sponsers are hooking it up look around and pm them.i am going with the ls7 i really dont like shatter and they hang in there pretty good do a search
Old Dec 12, 2009 | 12:07 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
ls7 clutch is a very hardy clutch, i have a customer launching on a nitrous shot on drag radials and some the clutch is still holding.... this car is making about 580 rwhp on the unit.... but by all means i do not recommend this with any single disc organic clutch...
with that said the textralia or monster will work (same clutch just one is green the is yellow) but in my opinion all of them drive like crap and chatter to some degree because no matter how you market it... it is still a puck metallic clutch disc and that is the nature of the beast. if you want great reliability and great power holding i offer the rps twin organic clutch for $1200 (flywheel,discs,plates and pressure plate) which has about 10% stiffer clutch preesure but engagment is nearly like stock, and no need for any aftermarket master or shim.... is isnt cheap but believe me the quality is there
Old Dec 12, 2009 | 01:12 PM
hlaalu's Avatar
another +1 for the ls7 clutch, works great on the street and takes my abuse at the track
Old Dec 15, 2009 | 11:00 AM
snugans310's Avatar
koo thanks for the info keep it coming tho
