Western Members CA, AZ, NV, UT, CO, NM, HI
Power window problem. Regulator or motor??
Old Mar 16, 2010 | 12:44 PM
chevystyle's Avatar
Default Power window problem. Regulator or motor??
As we all know, the windows tend to stop half way up or down, but will close completely avenchaly. Motor or regulator? What is a regulator anyways?
Old Mar 16, 2010 | 01:13 PM
ss.slp.ls1's Avatar
Motor.
The regulator is the metal contraption that the window motor acts on to move the window up and down, seen here:
http://shbox.com/1/window_regulator2.wmv
If the regulator was bad, the window would likely come up crooked or not close completely.
Old Mar 16, 2010 | 01:21 PM
ssbowtie1's Avatar
Its your motor but greasing the regulator helps keep friction down and helps the motor last longer.
Originally Posted by chevystyle
avenchaly.
Sorry but I just have to at that.
Old Mar 16, 2010 | 01:30 PM
94'BLKBRD's Avatar
Old Mar 16, 2010 | 01:37 PM
98boxer's Avatar
it is your window motor, make sure to pay full attention NOT to drill out the rivits that hold the window mechanism. If you can see the rivets you may think you have to drill out, then its not them. The rivits you drill out of the original window motor are not seen untill you drill a hole on the door to get to them.
