Bump Stop Mod QUESTIONS
I wanted to ask if P&P my MAF will cause trouble for tuning later on when i start building my car. I wanted to cut the two metal ridges off
both ends, i read on install university that it makes the car run a bit faster cause it makes it run rich? If i did this mod and later when i take it to get it tuned will it be impossible to tune cause of this, i don’t mean the screen, i don’t want to descreen the maf just remove the "Pillar" that encompasses the center sensor in the plastic maf.
Thanks for you answers. Let me know what you guys know...
How can I adjust or fix the pedal or cable to take advantage of the Bump Stop Mod?
Can I P&P my MAF without causing problems for tuning the car later?
this MAF mod
FWIW I would not touch your MAF. Go out and get a 85mm truck MAF and call it a day.
