Western Members CA, AZ, NV, UT, CO, NM, HI
Need some ones help
Old Jun 12, 2010 | 12:20 AM
tiger70h's Avatar
Default Need some ones help
Getting 4 diffrent codes for o2s heater circuit one of the them is po135 bank 1 ,sensor 1 malfunction , bank 1 ,sensor 2 malfunction and both of bank 2 sensors. And i all so got p0327 knock sensor 1,2 circuit ,low input. Can so one help me please. Someone all so told me that i dont have a knock sensor conected at all is that possible ? My motor is a 02 and its in a chevelle can you tell me where the knock sensor is?
Old Jun 12, 2010 | 12:30 AM
mannyman84's Avatar
Check your connection on that knock sensor and O2 sensors. Bank 1 is left side if I'm mistaken. U have 4 O2 sensors. Two left before and after the cat and right is bank 2
Old Jun 12, 2010 | 12:46 AM
tiger70h's Avatar
Wheres the knock sensor located ? Some one told me i dident even have it connected but they never showed me where it was at can some tell me
Old Jun 12, 2010 | 12:57 AM
lowerthanyou00's Avatar
If its a ls1 they are underneath the intake manifold, there's a connector behind the intake that connects to the harness that connects to the knock sensors. Check the connector behind the intake. Do you have any o2 sensors connected?
Old Jun 12, 2010 | 01:09 AM
tiger70h's Avatar
So there undernea knocth the intake manifold and not on the side of the block like other people say. And i have all 4 o2 sensors but no cats what do u think my problem is ? And what dose the knock sensor look like ?
Old Jun 12, 2010 | 01:15 AM
Yes underneath the intake manifold but there's a connector in that very back that u can check without ripping the intake off. Ur rear o2 aren't doin anything important other than letting you know you have no cats. Have a sponser tune the rear o2 sensors out to where ur computer won't use them.
Old Jun 12, 2010 | 01:21 AM
did you need to start 6 threads on this? we have a search feature on top that can be used and u will find all of your answers
Old Jun 12, 2010 | 01:25 AM
tiger70h's Avatar
Do u have any sugestions of who to take it to ? So about the o2s, do you think its the front ones are bad ? Thanks
Old Jun 12, 2010 | 01:28 AM
If your in so cal take it to cms.
tiger70h's Avatar
My fault no one was answering & this is my first time on this site .
Old Jun 12, 2010 | 01:30 AM
tiger70h's Avatar
Ok ill look them up thanks
Old Jun 12, 2010 | 01:35 AM
Arc00TA's Avatar
Where are you located at?
Old Jun 12, 2010 | 01:36 AM
tiger70h's Avatar
La in south gate
