Western Members CA, AZ, NV, UT, CO, NM, HI
Fixed
Old Jul 18, 2010 | 01:34 PM
NiteRiderWS6's Avatar
Default Fixed
Delete Thread
Old Jul 18, 2010 | 01:56 PM
Ryphraph's Avatar
Try cleaning your air filter and throttle body. I used to get p420 and after cleaning no problem.
Ryph
Old Jul 18, 2010 | 02:52 PM
RPD_Vette84's Avatar
i just had this code. it means your rear o2 sensor isnt reading right which means your cat could be goin bad. what i did was add a spacer to the o2 bung to space the o2 sensor away from the exhaust flow plus my buddy just tuned out my rear o2's. havent had that code since. if that doesnt solve it then you probably have a bad cat (if you still have cats)
Old Jul 18, 2010 | 05:08 PM
mannyman84's Avatar
Sounds like a fuel pump. good luck
Old Jul 18, 2010 | 08:31 PM
SUCK MY SS's Avatar
bad cat
Old Jul 18, 2010 | 09:07 PM
B Layton's Avatar
Default Check this out it may help
http://www.v8sho.com/SHO/P430.htm
Old Jul 20, 2010 | 12:57 AM
thanks for all the help, appreciate it. Im going to take care of the bad cat and then make sure the fuel pump is ok
