Western Members CA, AZ, NV, UT, CO, NM, HI
LT1 block
Old Aug 26, 2010 | 06:06 PM
EliteCamaro94's Avatar
Default LT1 block
Does anyone know where I could go to pick up an lt1 block? Im thinking about slowly building one up. Just buying parts here and there and then when its done swapping it into my car. If anyone knows a good place to get one let me know thanks.
Old Aug 26, 2010 | 06:45 PM
ss.slp.ls1's Avatar
Question
I'd hit up Ecology Autoparts. They usuallly have a few LT1 cars in there (Camaro, Trans Am, Roadmaster, Fleetwood, Impala) and you can get the whole engine for something like 200 bucks. Then you can dismantle it yourself and have the bottom end rebuild (forged parts or stock), the heads machined and/or polished, order a cam kit of your choice, etc.
Old Aug 27, 2010 | 09:15 PM
thats a good idea, will the motor from the other cars listed drop right into my camaro? Also do i need to find a 94 model yr or will anything 93-97 work ok in my car.
Old Aug 27, 2010 | 10:01 PM
hitmanws6's Avatar
The blocks are the same, the differences would be the cam dowel pin and timing cover because yours is OBD1
Old Aug 28, 2010 | 01:49 AM
383lt1impala's Avatar
The cam dowel or spline differance in the cam has nothing to do with the block... the obd2 or 1 either the differance in that would be a gear on the crank and differant timing cover. the only main difference in the blocks would be its either 2 or 4 bolt mains. If im wrong correct me.
Old Aug 28, 2010 | 12:33 PM
jester1614's Avatar
i have a lt1 block that i would let go for like 50 bucks it is disassembled and needs a bore.
I am in avondale. message me if your interested
