Western Members CA, AZ, NV, UT, CO, NM, HI
rearend HELP
Old Oct 11, 2010 | 09:10 PM
snugans310's Avatar
Default rearend HELP
ok so something went really wrong with my moser 12 bolt one of the ring gear bolt got loose and grinded the hell out of my ABS 3 Channel Exciter Ring you know the lil gear that goes around the posi everything else is ok well i got a true trac posi and my local rearend shops dont carry the one i need someone please point me in the right direction were i can buy thanks
Old Oct 11, 2010 | 10:40 PM
GARAGE_BUILT_Z28's Avatar
Idk but try posting in the Gears & Axle section you might get a good answer...
Old Oct 12, 2010 | 02:38 AM
rixsgto's Avatar
You talking about the reluctor ring on the carrier? If so ill see if I can find one.
Old Oct 12, 2010 | 11:40 AM
snugans310's Avatar
Koo thanks rixsgto ima call moser later to see what up
