need elect fans for this set up.. any suggestions?
damn.. i was afraid u guys were gonna ask for more..
its a 2003 toyota tundra
**** had **** a 3.4 v6 s/c @ 16lbs w/ full meth..
blew it chasing down my boys .. procharged 6.0 @ gorman..
so it was time for my ls swap..
*** TOYOTA TUFF W. CHEVY NUTS ***
SOME GOOD MOUNTS
POLY TRANS MOUNT
SO WHAT TO USE???
SOME GOOD MOUNTS
POLY TRANS MOUNT
SO WHAT TO USE???
If u could modify the radiator support to move the radiator lower and forward you might get enough room. U could mount the radiator in front if the support but then your grill wouldn't fit or you'd make a custom grill.
yea. i was thinking that.. but the hood latch is on the radiator support too.. so its tricky
and moving the radiator to the back means a lot more problems with plumbing and adding a water pump.
ima try moving it down and to the front ..
but wat are some good fans so i can try to fit em
