Western Members CA, AZ, NV, UT, CO, NM, HI
Clutch noise
Old Nov 20, 2010 | 01:56 AM
hlaalu's Avatar
Default Clutch noise
I posted in the trans section of the forum but no one says anything lol anyways, my problem is when the car is running and stopped, with the clutch pressed in, I hear a clanking noise coming from the clutch area. Could it be my slave or master? When the clutch isn't pressed in and the car is in neutral, there is no abnormal noise coming from that area.
Any advice would be helpful!
Old Nov 20, 2010 | 08:42 AM
Datzneat's Avatar
Long shot but have you checked the spring thats attached to the pedal? Mine used to make alot of noise.
Old Nov 20, 2010 | 03:09 PM
haighter's Avatar
Sounds like a pitot bearing. Could be a few things but I would look into that first. When's the last time you replaced it? Is it a growling or houling sound from the bell housing when you press the clutch pedal? If you have any more questions feel free to give me a call or pm.
Old Nov 20, 2010 | 03:13 PM
99 Blue Bird's Avatar
i dont think its your slave. that would make a noise when the pedal was not pushed in. and it does not make a clunking noise at all. do you have a adjustable clutch master cylinder? if so might want to try some adjustments.
Old Nov 21, 2010 | 01:44 AM
hlaalu's Avatar
yeah spring is good.
replaced the pilot bearing when i replaced the clutch maybe 40k miles ago. i wouldn't call it a houling sound, more like a growling.
nope just the stock master.
I guess what ever it is i need to take my tranny off
Old Nov 24, 2010 | 12:27 AM
hlaalu's Avatar
bump. anyone have some more ideas? i think im just going to order a new ls7 clutch kit and a new slave cyl. while the deals are good this week.
Old Nov 24, 2010 | 05:34 AM
Soul TKR's Avatar
That's what mine does!
gonna pull the tranny and replace the pilot on mine. We'll see if that works or not. Should be fun, It'll be the first time for me pulling the transmission so...
Old Nov 24, 2010 | 10:24 AM
haighter's Avatar
Ive heard yours, yours is the clutch disk. Myself and a lot if other people have said the same thing.
To the OP, without seeing or hearing it. It can be a few things. The only way to tell is by pulling the trans and inspecting everythig.
Old Nov 24, 2010 | 04:25 PM
hlaalu's Avatar
when are you doing yours?
yeah that's my plan. but without a lift if i'm going to take my tranny off i might as well replace my clutch with 50k miles
