Western Members CA, AZ, NV, UT, CO, NM, HI
driveshaft help
Old Dec 13, 2010 | 06:53 PM
rhinosarge's Avatar
Default driveshaft help
so i got a 6.0 with a 4l60e in my 2003 tundra.
toyota driveshafts are all 2-piece slip-in
and from what i know
chevy driveshafts are 1-piece slip-in
so heres the dilema
should i juss measure up the driveshaft and have the 4l60 yolk welded to the yota driveshaft..
or should i find a 1 piece truck driveshaft and get it fitted for the tundra.
im juss worries about the geometry and the angle... and all that good stuff.. i had a friend telling me if theres too much play the ds can slip out. or too long i can break something.. what will work best??
thanks for the help.
__________________
Old Dec 14, 2010 | 01:29 AM
xXxSilveradoxXx's Avatar
Well, your first idea won't work. You can't have a slip yoke and a variable length drive-line. The way I see it is you have two options;
1. Get a slip yoke eliminator for your transfer-case and run the Toyota drive-line (if it has acceptable travel) with a conversion u-joint in the front.
2. Have a one-piece drive-line made with the GM slip yoke in the front with a conversion u-joint in the back.
If I were you I'd go with #2, easier and cheaper.
