NO oil pressure????
Help please. And thanks
How many miles on the motor? problem with an oil pump taking a dive is that it is so crucial that it usually requires more extensive repairs than just remove and replace.
As asked earlier, how many miles on the car? Original oil pump?
If it was me, I would make sure it wasnt getting pressure & that the oil sender was accurate. Then i would replace the pump & the o-ring on the pump. Its a PITA to do, because you have to loosen the oil pan so it can drop a little. Make sure you have a pen magnet too as im sure you will drop the bolt to the oil pump. If you do that take some pictures of the inside of the oil pump and post them. Im wondering if its not all scared up inside. Also check the status of the oil o-ring that goes into the pump... maybe its not sealing?
Keep us posted.
