Western Members CA, AZ, NV, UT, CO, NM, HI
97 LT1 Build
Old Oct 11, 2011 | 09:53 PM
94'BLKBRD's Avatar
http://advancedinduction.com/
Old Oct 11, 2011 | 11:11 PM
ConElite's Avatar
never dynod. on a mail order tune. Its on a 2500 stall on 3.42's
Best was a 12.31 with a 1.8 60' up at Famoso. Im guessing its around 360whp.
Old Oct 12, 2011 | 12:25 AM
henry172's Avatar
That is about what I think I should be running. I only put done something like 340whp at cms, but I have a 3200 stall and t-top car. I am running the 24x ignition with a ls pcm. I need to fix a couple problem with my Idle. I am thinking the IAC valve is a problem and I have a P0332 code that keeps comming on; maybe a bad knock sensor.
AI's web site has been posted. You could just buy a short block then install the heads and cam of your choice; it will save you some down time on rebuilding your shortblock. Like already mentioned you will also need all of the supporting mods; headers, cold air intake, electric water pump, NSA roller rockers, fuel injectors things like that. I am leaving a few hp on the table with my short headers; but I wanted it to look smog legal.
Old Oct 12, 2011 | 01:01 AM
Zlow28's Avatar
Id skip on the underdrive pulley, and the throttlebody wont help unless you have a ported intake manifold and enough power to make use of it. Lloyd elliot and advanced induction will most likely be the top 2 people to send your heads to.
For bolt ons get, 1.6rr, valve spring, pushrods, and maybe lifters. These will be to support any cam. Headers help out a lot too, and +1 on suspension.
For AI's website, google Advanced Induction. Should be the first link. The stall would mainly depend on the cam you go with. Theyll recommend one for you.
All this is going to add up pretty quick, so be ready to stretch your budget.
Old Oct 12, 2011 | 09:25 AM
1SLOLTX's Avatar
i have another question..is it possible to run a custom with stock heads..it seems like when your in the street racing world in los angeles all u hear is pop your hood..so im trying to build a sleeper lt1 with out having to put different heads on the engine..can someone lmk if this is possible..would i have to port and polish my stock heads ?
Old Oct 12, 2011 | 10:15 AM
JodyJ's Avatar
all Custom. Tons of hours going back and forth to Ace hardware. There is no adapters for the ARP studs. what a pain in the butt!
OK, thanks for the info.
Old Oct 12, 2011 | 10:59 AM
ConElite's Avatar
Yeah dont waste your time on the Underdrive pulley or Throttle body. Think the 58MM you get max intake at like 65% throttle. Only worth it if you do LT4 intake and P&P heads. We still run the stock TB.
ZLow28 has good points.
p.s. we run a custom grind cam with stock heads just upgraded Springs and retainers.
Old Oct 12, 2011 | 11:54 AM
Zlow28's Avatar
Yes, you can have a custom cam and still keep stock heads. But nobody will be able to tell if you have stock or ported heads by just looking at the engine bay. Also keeping your heads stock will really limit the size of your cam. If you can afford heads, id say go for it. It will open up a lot more options and make better use of a custom cam.
What are your goals for the car?
Old Oct 25, 2011 | 06:41 PM
1SLOLTX's Avatar
Originally Posted by zlow28
yes, you can have a custom cam and still keep stock heads. But nobody will be able to tell if you have stock or ported heads by just looking at the engine bay. Also keeping your heads stock will really limit the size of your cam. If you can afford heads, id say go for it. It will open up a lot more options and make better use of a custom cam.
right now my goals are to mild built ls1's with my lt1..
Old Oct 26, 2011 | 10:30 AM
ss.slp.ls1's Avatar
I would give AI a call.
Old Oct 27, 2011 | 08:13 AM
SS MPSTR's Avatar
Agreed.
Old Oct 27, 2011 | 09:28 AM
  #32
ss.slp.ls1's Avatar
My '97 SS w/ CC503 cam, LT headers, and TB made easy work of most mildly modded LS1's. That cam is one of the largest off the shelf cams that will work effectively with stock heads.
Old Feb 12, 2012 | 08:28 PM
  #33
1SLOLTX's Avatar
i have a friend sellin a cam out of his lt1..these are the specs he gave me on it isky cam 110 lsa about 565/585 lift with 1.6rr ..what supporting mods will i need with this ? and how much would it cost me
Old Feb 13, 2012 | 10:09 AM
  #34
ZSS2148's Avatar
If I were you I'd find myself a good shop and let them shove you in the right direction. There's too much to learn/know when it comes to not waisting money. Btw, the specs you gave can be any of 700 different cams. Pm if you're serious about going fast.... (I know this spot in Anaheim.)
Old Feb 22, 2012 | 01:31 PM
  #35
CESARZ's Avatar
do all the bolt on's and suspension them work on heads and cam package..and some nitrous?????
