Need Help:Heater problem..
Thanks in advance.
check this out - https://ls1tech.com/forums/general-m...8-no-heat.html
there also - http://shbox.com/1/4th_gen_tech2.html#heaterflush
check to see if your leaking coolant and also check under your glovebox inside the cab to make sure your heater core hasn't failed and is leaking onto the carpet (happened to me)
#flush system, change thermostat, check heater hoses for clogging, ensure your coolant is full
