Western Members CA, AZ, NV, UT, CO, NM, HI
Injector question for nitrous???
Old Mar 13, 2013 | 09:22 AM
chevyrunner's Avatar
Default Injector question for nitrous???
I have a heads/cam ls1, stock internals, i just put a wet kit on to spray about a 150-175 shot, i have a aeromotive 340 fuel pump...
My question is will a 36 pound injector be ok to use as my injector for this set up... I took off the stock ls1 injector and put in a 36 pound denso injector from a 5.3???
Old Mar 13, 2013 | 01:05 PM
180ls1's Avatar
take those injectors back off your car till you can get it tuned for them. You can wash the cylinders and kill your motor pretty quick doing that.
Old Mar 13, 2013 | 10:30 PM
the car has actually been tuned with red top#36 injectors, but im just wondering if 36 will be enough
Old Mar 13, 2013 | 11:21 PM
justinj's Avatar
You don't need bigger injectors with a wet kit, the fuel is already supplied. You will be fine.
Old Mar 13, 2013 | 11:33 PM
the car is in the upper mid 400s on the motor , then we added a intake/tbody so im wondering if the 36# is enough.. i dont want to be maxing the injector out
Old Mar 15, 2013 | 08:50 PM
justinj's Avatar
You need to do some research. A wet kit doesn't make the injectors work harder. You are just revving the motor faster. If you had a dry kit I would say hell yes and also a tune would be a must. With a wet kit a little adj of the timing and your good to go depending on the shot you wish to use. The fuel is being supplied from the kit.
Old Mar 23, 2013 | 10:14 AM
badls1's Avatar
+1 with justinj
On wet kit adds its own fuel, that is why you have (single fogger) 1 nitrous jet and 1 fuel jet. Make sure your final timming is not to high.
Old Mar 26, 2013 | 12:32 PM
camarojunky74's Avatar
+1 on what these guys are telling you, hopefully you have the setup now dialed in before adding n20.
My suggestion is to work your way up to the 150/175 shot. Start at a 50 and so on. There is no shame in that. It's probably the best way to learn how your car is going to react progressively on the bottle. And you as well. I would so recommend you get a window switch and fuel pressure switch and a bottle pressure switch nothing worse then an intake manifold exploding thru your hood.
Personally I've had a stock car on the bottle successfully for about 5 years now. I didn't cut corners on the setup or the tune. And am running mid low 11"s on a stock motor stock clutch rear end etc. just go easy and be conservative.
Hope this helps. I would also field any questions thru nitrous Dave's should still be a vendor on here.
Old Mar 26, 2013 | 01:23 PM
HCI2000SS's Avatar
You really feel safe spraying a 175 shot on HCI stock internals LS1 that's already high 400's on motor lol? You got more ***** than I do man...good luck with that lol
Old Mar 26, 2013 | 10:48 PM
More ***** or more money lol or less knowledge could be either of those or maybe all 3 ! Who knows
