Western Members CA, AZ, NV, UT, CO, NM, HI
Need help need mechanic!!
Old Aug 30, 2014 | 10:25 PM
LS1TAUTO's Avatar
Default Need help need mechanic!!
i need someone thats reliable and have done cam swaps before looking to have my torquer v2 cam installed with a set of valve springs rods and maybe oil pump i live in MODESTO ca willing to drive but not to far 25 miles max give me a call or txt if interested and a good deal would be greatly appreciated!! thank you (209)681-1852
Old Aug 30, 2014 | 10:27 PM
"MAC"'s Avatar
Might wanna spring for some lifters as well depending on the milage.
Old Aug 30, 2014 | 10:37 PM
LS1TAUTO's Avatar
im around 80k
Old Aug 30, 2014 | 11:09 PM
"MAC"'s Avatar
Id still replace lifters as good measure. usually when doing a cam swap its a good idea to do it. Get ls7 lifters bare minimum there are better ones out there. Also to help you out with the cam install, go to the local drag strip and ask around to see who people go to and watch them run. this should give you a good idea how good there tuner is and how well the work is done.
Old Aug 31, 2014 | 12:11 AM
LS1TAUTO's Avatar
ya i was thinking might as well....i have a good tuner on hand just no mechanic
