Western Members CA, AZ, NV, UT, CO, NM, HI
Looking for engine machining/assembly in SoCal
Old Feb 9, 2016 | 03:06 PM
ZexGX's Avatar
Default Looking for engine machining/assembly in SoCal
Looking for a good shop to machine/assemble my forged 370ci LQ4 shortblock (or longblock for the right price) in SoCal. Have most parts. May need to buy bearings if the ones I have don't have the correct tolerances. Prefer shops that know how to machine things properly & and install things properly, like clean/proper installation of the front timing cover, installing the pistons in the correct orientation, etc.. The last place I went to didn't do that. I won't name names.
Needs to be bored .030 over using an LS style plate & matched to BNIB Wiseco pistons. One cyl has some corrosion which should be fixed after the boring. May need checking for cracks as it will be boosted with a D1SC & high compression under boost (10.x:1 NA).
Stock LQ4 crank, lower mileage, was in LQ4 shortblock which was working when torn down.
BNIB Callies Compstar rods.
I know about QMP but would like other recommendations.
Old Feb 12, 2016 | 01:45 AM
Don Nguyen's Avatar
Let me know if you find a shop. I am looking for some block work done as well.
Old Feb 12, 2016 | 05:40 PM
CBM Motorsports's Avatar
We are in SoCal as well. I am sure we can do everything you are looking to get done and do it right the first time. PM me if you need some more info.
Old Feb 12, 2016 | 08:46 PM
Badazz 97 TA's Avatar
Arce engines in El Cajon did my rebuild. No problems so far. Nice guy and small company. He does asphalt car racing on the side. Does a lot of GM stuff.
Affordable price and was done in 1 month.
Old Feb 15, 2016 | 03:50 AM
oChristiano's Avatar
Mulleunix or go through Alex
Old Feb 19, 2016 | 01:42 AM
JDM 187's Avatar
You can try talking to Martin at CPR in Gardena.
Old Feb 19, 2016 | 01:03 PM
Frank C.'s Avatar
Custom Performance Racing Engines
In Gardena gets my vote, I've done quite a few builds and used them for my machining with great success.
Old Mar 16, 2016 | 06:01 PM
ROCNDAV's Avatar
Did you ever decide on a place?
Has anyone ever been to VAP (Valley Auto Parts) Engines in Sun Valley?
A coworker of mine is related to the owners and I was thinking of taking my rotating assy there for balancing.
http://www.yelp.com/biz/valley-auto-...nes-sun-valley
Old Mar 19, 2016 | 08:35 PM
1Psycho's Avatar
We can do it as well
