need help on fuel pump install (LT1)
*I will attatch pictures here in a sec to give u guys an idea of what im dealin with
they wont fit, the filter hole os too big...i was thinkin of getting a rubber tube that fits around the male end and supergluing the **** out of it so the filter would be snug on it...any thoughts? ......
**** btw its a walbro 255 pump kit***
I'm not having any problems with my pump, and i've run it down to .5 gallons left in the tank. it might not be the best for pump longevity doing that because the fuel keeps the pump cool, but if you keep a gallon or two in the tank you don't need the plastic case.
yea the filter was already mounted on the pump, so I just hose clamped the pump onto the swingin' arm with the horseshoe shaped thing at the bottom of the arm kinda snapped between the body of the pump and the filter. been working fine for 1k miles.
remember to prime the pump quite a bit before you try to start your car, you'll definitely hear when the pump is building fuel pressure. also the pump whines a bit more than stock, as in, you'll hear it all the time when you're driving with the windows up.
lol i reread your post and I understand what you're asking now, ya I dunno how to mount the filter, sorry man... but if you're gonna put the plastic case back in use a quick epoxy, or I think you can use superglue since you cracked the thing open before.
but how did you keep your pump in place? without the bottom of the case wouldnt it move?
Think of it like a chinese hand cuff the metal tin ring to the plastic nub sticking out
