Some 6.0 tech questions...
O its going in a 65 el camino with a t350 4000 stall 3.73 gears thanks....
I think if you milled the heads a bit and went with a thinner cometic gasket (say the .040) you could get the compression up a bit. Maybe a nice nitrous grind and you might be able to squeek out 650 rwhp that'll last a while. A good tune will do the nitrous runs a great deal of good.
