Western Members CA, AZ, NV, UT, CO, NM, HI
Need a tuner in 626
Old May 11, 2007 | 05:56 PM
LSGunZ28's Avatar
Default Need a tuner in 626
My car is acting crappy, it keeps idling rough and dying at times also my battery keeps acting up, when I turn the key on and try and crank it, sometimes the car dies, I re tighten the battery negative wire and the car staRTS BACK UP BUT RUNS ROUGH. LATER ON the car starts idling normal again, until the battery decides to die again. Either way I need a tune, my car doesnt feel like its running as strong as before.
Old May 11, 2007 | 06:49 PM
craparo's Avatar
i would check out your fog lights that happened to me because one of my fog light bulbs had gotten water in it.
Old May 11, 2007 | 09:11 PM
LSGunZ28's Avatar
well it hasnt rained here in a while, its So Cal and its so damn hot!!! I hate it!
anyways, I still need a tune. But I will look into that.
Old May 11, 2007 | 11:49 PM
craparo's Avatar
yeah just a heads up. i dnt think it is your tune tho if ur car was running fine before. and it doesnt rain i live in so cal too, but sometimes at night it gets pretty cool and condensation builds up i guess thats what they told me how it started and it shorted everything out
Old May 12, 2007 | 02:35 AM
LSGunZ28's Avatar
Yeah it keeps doing it man. but when I jerk the negative terminal and re tighten it, it fires up and wants to die and a minute later it idles normally @ 800 RPM again. but when it wants to die it idles low as hell @ 500 RPM.
Old May 12, 2007 | 10:29 AM
travie319's Avatar
take it to your local autoparts store and get a charging system check......
Old May 12, 2007 | 12:49 PM
BigDaddyBry's Avatar
If you lost power/connection to the battery, your car is probably going through its relearn procedure right now.
Old May 12, 2007 | 01:09 PM
01black's Avatar
werd...mine did that when i took the stoopid jet chip the previous owner installed and re hooked the pcm.
