NEED HELP, QUICK! Bad Fuel Pump?
You don't have to drain the tank if you do the access panel mod from the top. You only have to drain it if you plan on dropping the tank.
Better not drive much if its overheating or you can kiss your headgaskets goodbye.
I really doubt that it's your pump.. they either work or don't work...
I know a middle aged guy who owns a mechanical/body shop and they said that most of the time they just die.. I'm sure there are cases, such as yours and some others, that it just craps out slowly but I don't think this happens often...
So why wouldn't you just pull your O2 and check the things that are more common and that are cheap, easy tests instead of put money and time into cutting an access and buying/installing a new pump to just take a stab at it?
Unless someone around here has an auto tap that will work on my OBD1...
my car is dying on idle once every drive cycle, and hesitating. its also running a little hotter than usual. hard hot starts.
the check valve is bad on my pump for sure.
pushed opened the schrader valve, and one quick spray of gas folowed by dribbling with the key on= no pressure.
haha.. To all the haters and non believers, told you so..
Just weld in a replacement pipe and don't spend the money on another cat.. haha..
but Dan, for your Cats to clog up with that kind of mileage, you must be, or have been running really rich for some time...I would check those plugs since they are new and look for signs of running rich. If they are dark on the tips you are rich and we need to figure out what's causing that. Have you run a fuel pressure test yet? It sounds like it's not fixed yet, I would say the Cat's are from the result of running rich and we need to figure it out. I would bet on injectors or it could have been your filter. You would know if your pump was good, you can hear it kick on when you turn your key to the on position. If you are coming up on 60,000 miles you will also want to change your water pump soon. That is one thing you don't want to wait to break to fix. GM decided it would be a good idea to put your opti right under the water pump so when it goes, so does your opti. I can help you with your water pump when I get back if you want to wait, if not, it's not too bad. Might take half a day at the hobby shop. Might as well do it since you are flushing your coolant anyways.
As for running a little hot...check and see if your heater core is leaking. remove your glove compartment on the passenger side (just open it, push in on the ends and it should pop out). You will have to remove a black cover on the heater core and see if it's leaking. Has your car smelled like coolant at all lately? Whoever put the wrong coolant in there could have caused a blockage and it's not flowing well. I hope you get everything worked out man and don't stress it. I don't mind when things break cuz it gives me an excuse to get out there and turn some wrenches.
I don't think it's your opti, your car is not having the symptoms of it from the sounds of it. When your opti is going out...your car will bog and feel like it's trying to shut off while you are driving on the highway. Then when it goes you wont be able to go faster than 25 mph. You'll know, it sucks.
