Western Members CA, AZ, NV, UT, CO, NM, HI
headers question
Old May 28, 2008 | 10:08 PM
alc80's Avatar
Default headers question
on pacesetter's website they say their mid length headers are 50 street legal. can anyone confirm or deny this for cali? thanks
Old May 28, 2008 | 10:13 PM
CaliforniaBoy5's Avatar
confirm if you keep the cats
Old May 28, 2008 | 10:47 PM
alc80's Avatar
would high flow cats, such as slp, remain legal as well? thanks
Old May 28, 2008 | 10:52 PM
BigDaddyBry's Avatar
What's the CARB EO number on those headers so I can put that on my Jet Hots?
Old May 29, 2008 | 12:03 AM
MaroonLS1's Avatar
Any modification that moves the cats from its stock possition is illegal. Now you could pass the sniffer but not the visual
Old May 29, 2008 | 12:14 AM
LS1stunna's Avatar
If its 50 states legal, Im pretty sure the 51st state is California. Almost everything is illegal in Ca.
Old May 29, 2008 | 01:27 AM
black_phoenix's Avatar
yeah but with stock air box lid that takes up a lot of room in the engine compartment might cover them up, just a little though...
Old May 29, 2008 | 02:23 AM
i hope your kidding...
Old May 29, 2008 | 03:30 AM
MaroonLS1's Avatar
hes not ... technically any modification on your car is illegal. Im telling you CA sucks when it comes to these things
HA! but Im running LT headers with no cats! wat now!
Old May 29, 2008 | 07:53 AM
For the headers he's looking at, he'd pass the visual. They are 50 state smog legal and they retain the stock cat location.
CARB EO: http://arb.ca.gov/msprog/aftermkt/de...eo/D-439-6.pdf
Let's stick with facts, not speculation.
Old May 29, 2008 | 11:58 AM
hlaalu's Avatar
they let these 5mpg suv's and 4 foot lifted trucks flood the streets but its illegal for us to put on headers.
Old May 29, 2008 | 12:49 PM
No. I meant...
Last I checked there were only 50 states in the USA
Old May 29, 2008 | 01:45 PM
MaroonLS1's Avatar
All that is is a summary of how that pacesetter header is made and that it does not move the cats from its stock postion.
Old May 29, 2008 | 04:55 PM
If you don't know what a CARB E.O. number is or what it means for aftermarket parts, then you need to educate yourself. We all do for that matter.
In other words, this quote, as it applies to the OPs original question:
is incorrect. Unless you were referring to something else. If so, my bad.
Old May 29, 2008 | 05:27 PM
MaroonLS1's Avatar
It is not incorrect. The carb eo that is given when you buy either shorty headers means that the stock position of the catylitic converter has NOT changed and therefore would pass visuals. That is why CARB EO are not given to LT headers. If the smog station sees any aftermarket modifications under your hood, the CARB EO number is what they are going to ask you for.
Old May 29, 2008 | 05:42 PM
C'mon Vic, in one quote you say "it will fail the visual" and in another you say "they'll ask for the CARB EO #" which states its a legal header, meaning it won't fail the visual.
Did I miss something?
Here's a quote from arb's website, maybe this will help out:
Exempted parts are add-on or modified parts that have undergone an ARB engineering evaluation. If the part or modification is shown to not increase vehicle emissions, it is granted an exemption to emission control system anti-tampering laws. This exemption is called an Executive Order (EO) and allows the modification to be installed on specific emission controlled vehicles. Every Executive Order part or modification has an assigned number that can be verified by Smog Check stations, BAR Referee stations, or by the ARB.
Old May 29, 2008 | 05:49 PM
MaroonLS1's Avatar
[QUOTE=BigDaddyBry;9457174]C'mon Vic, in one quote you say "it will fail the visual" and in another you say "they'll ask for the CARB EO #" which states its a legal header, meaning it won't fail the visual.
QUOTE]
It will fail visual if the technician sees that the cats have been moved, now if you show him a CARB no. he might just let u pass
Old May 29, 2008 | 06:01 PM
If you're referring to the part the OP asked about, that's not right. The info I provided is directly related to the part the OP questioned about. Not speculation, but fact.
Not trying to be a dick, but it looks like you have the wrong info. This leads to much mis-information on this topic.
Bottom line: If you have a CARB EO number for your smog-legal header, you will pass.
Last edited by BigDaddyBry; May 29, 2008 at 06:55 PM. Reason: I sounded like a dick.
Old May 29, 2008 | 06:05 PM
According to Pacesetter's website, all headers indicated as 50-state smog legal are so under EO #: D-439-6.
http://www.pacesetterexhaust.com/camaro.php
Therefore, to answer your question, yes they are legal in Cali.
END OF STORY
Old May 29, 2008 | 06:09 PM
hlaalu's Avatar
so then even if the cats are moved, as long as it has an EO number it bypasses the fact the cats are not in the stock location and makes it legal?
