Western Members CA, AZ, NV, UT, CO, NM, HI
p600b help
Old Jul 13, 2008 | 06:22 PM
trans am you lose's Avatar
Default p600b help
Im installing this on a 93 TA and I recieved a book for a p1sc.dum Where does the feed and drain lines go? Thanks
Old Jul 13, 2008 | 10:21 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
there should be a oil pressure pick up on the driver side above the oil filter if i dont recall, i would use that for feed, then i would just drain it into the oil pan above the oil level. hope this helps
Old Jul 13, 2008 | 10:36 PM
SUCK MY SS's Avatar
make sure wherever on the pan you decide to place the drain, that it is above the oil level...or else the oil will not drain properly from the supercharger..
i had an issue with a twin turbo corvette i did, that had a gravity drain from the turbos instead of a pump...the placement of the drain tube was put in a spot that restricted oil drainage anytime the car was on an incline/decline, causing it to slightly smoke... now this may not seem like a big deal at first, but it can potentialy blow out the seals inside, due to excess pressure...
Old Jul 14, 2008 | 04:07 PM
Thanks Ryne and Suck my ss, Kitty what the hell are you doing here? burn
Old Jul 14, 2008 | 04:09 PM
I was thinking i would weld a nut on the oil pan and drill it out and screw the line in thru there. Would right below the timing chain be an alright place? well not right below, but on either the left or right side of the U shape or the timing chain cover.
